lambretta engine mounting position, 2 hole
holty
Main scooter: lambretta gp
hi folks can one of you comfirm the position of the kickstart silent block, its a 2 hole type,gp type, it will be indian, im only changing it as im fitted a casa flat bar with offset cones, think sticky book says hole between 10 and 1 oclock, does that sound right ? on a 3 hole I always put the bottom hole at 6 oclock and the other holes towards the front of the scooter ?
thanks in advance,
holty
db67
I think it should be fitted with the holes at 2 & 4 o'clock on the kickstart side, I believe the "voided" 2 hole Indian type were fitted at 10 & 1 but I think this type of mount hasn't been available for a long time, hope this helps ;)
    Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 12 guests
