Lambretta crank induction with Malossi MHR 221
wrecklessrobbie
Main scooter: li150
Hmmm..been a strange summer so far.
Ive been getting soaked quite a lot at work this year.
Hopefully you will get good weather for it.
ducksta
Nothing happening on the build ?
mick1
Main scooter: Li Avanti 225
Not got a garage, so a bit restrictive at the moment
mick1
With the decent weather and a bit of time on my hands I decided to have another push with project.
Priority job was to strengthen the frame.
IMG_20200318_144054 by mick leaf, on Flickr
As you can see there nothing to support the rear section other than the 40mm tube.
So:This was made from 30mm tube with pre-formed bends and welded together
frame brace by mick leaf, on Flickr
Offering it up
frame brace offered up by mick leaf, on Flickr
and fitted
frame brace requires more weld by mick leaf, on Flickr
The next stage is to whip the engine out and do some significant welding.
By the way the forks are the original Ld but they won't be staying.
A bit more fair weather and hopefully i'll be on the road !!
mick1
Hmmm that's not very good. Thought the photos were ok but obviously not, tried to edit but it won't let me ?
Here's the pictures try and work out where they should have been.
ImageIMG_20190414_094449 by mick leaf, on Flickr
Imageframe brace by mick leaf, on Flickr
Imageframe brace requires more weld by mick leaf, on Flickr
    Users browsing this forum: No registered users and 31 guests
