Hi,
going to add a horn louder than the stock duck-fart. I'm converting back to a battery, so will have DC power. I'm wondering at what kind of amperage will the horn wires melt. Above that I will put a relay in place.
Tx
David
how many amps will the horn button support?
- Main scooter: Early Eibar Jet 200
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
Standard Lambretta cable is rated to about 8A. It's the switch contacts that are going to suffer, especially when switching DC and even more so if it is an inductive load. I'd fit a relay to protect the switch.
- Main scooter: Lambretta li150 special
If you have another use for the button you could always use a relay. Then the horn button would then just work the switching circuit.
- vegansydney
A full DC set up with a DC horn (original or remade) is loud, and has saved me several times from careless NYC taxi drivers. Bright lights from the conversion are an added bonus.
