vhsb dellorto carb tuning
holty
Main scooter: lambretta gp
hi, folks,
happy new year, im doing an upgrade to my 290 rotax and think a bigger carb may be the order of the day, firstl ive acquired a 38mm competition carb which I was thinking of using, needs a few bits and bobs replacing, but ive just realised it has not got a tickover screw, do you just use the air screw ? not sure really, then I have anther carb body that started life as a 36mm but someone has had it on a lathe and turned the inside to hake it bigger, has anyone done this before and had success, I am at the moment using the 34mm vhsb with the oval bore, obviously the round bore will flow more air, I realise that is more than one question, didn't seem to be able to find much info on internet either,
thanks in advance for any help given,
holty
    Users browsing this forum: Google [Bot] and 32 guests
