EGT meter fuse?
alanscottj
Hello all and Happy New Year!
I have just fitted a Stage 6 EGT to my Series 2.
Do I need to put an in-line fuse on? If so will 3 amp be ok as I already have some in the shed?
and
On the Varitronic ignition, am I right in thinking that the spare connector on the regulator is to charge a battery?
Many thanks!
Grumpy225
Is this what you have? https://www.scooter-attack.com/egt-gaug ... tore=sa_en
If it is then as long as there is a fuse some where between the battery and the rest of the system I'd think it would be fine.
yes, one of the connectors on the regulator is for DC out. I don't think it's very much, only good for trickle charging a battery.
alanscottj
Grumpy225 wrote: Fri Jan 04, 2019 1:09 am Is this what you have? https://www.scooter-attack.com/egt-gaug ... tore=sa_en
Thanks Grumpy225, I have fitted it now and put a 3 amp fuse between the battery and the display. Hopefully the trickle charge will be enough to keep the battery topped up :D
    Users browsing this forum: No registered users and 91 guests
