Series 2
cgt75b
Main scooter: lambretta
Hi peeps
Anyone using a removable panel hook on a series 2? Which supposedly makes it easier getting the back wheel if punctured.
Thoughts/experiences
Thanks in advance.
Jeff T
Main scooter: GP150 & LI150 S2
No but mine is just cut off, not by me but never had any issues
db67
Yes, that's the easiest option , you just need to remove between about 10 or 15 centimetres of metal from the outer bracket "hook" ,its a bit of trail & error until you can get the wheel off, done this on both my series 1's & its a big help ;)
db67
db67 wrote: Sun Dec 16, 2018 3:02 pm Yes, that's the easiest option , you just need to remove about 10 or 15 mm of metal from the outer bracket "hook" ,its a bit of trail & error until you can get the wheel off, done this on both my series 1's & its a big help ;)
db67
T
cgt75b
I'm a little confused now! Is this with the removable hook or not?
Many thanks.
Cgt75b.
db67
No, not as standard but you can buy a panel bracket kit off eBay that allows you to bolt/unbolt the bracket but you obviously have to remove the original bracket first to use one of these, or you could just modify the original one to make it removal ;)
    Users browsing this forum: Ahrefs [Bot] and 85 guests
