Tyres And Tubes
MightyGem
I use Michelin S83 tyres with tubes on my Li. The time's coming up to replace them.
Does anyone know if you can get tubes with short valve stems? The ones I've used so far can foul the nuts at the bottom of the forks if I'm not careful, so shorter valve stems would be great.
HxPaul
MightyGem wrote: Sun Dec 02, 2018 9:38 pm I use Michelin S83 tyres with tubes on my Li. The time's coming up to replace them.
Yes you can get shorter valve stems for front fitment,I've got them on my scooter,unfotunately I dont know what make they are.
paul d
Main scooter: T5 172 Tv 240
I use mypol tubes. They fit in every way without drama.
paul d wrote: Mon Dec 03, 2018 12:28 am I use mypol tubes. They fit in every way without drama.
+1 i use because the valves are off centre to suit Lambretta Rims
Scooterdude
Sounds like you are using the 90 degree angle valve on the front. This will foul the nut on the link bolt. You need to get a 45 degree valve tube, you can get them from AFRayspeed (the 90 degree valve is used on the back wheel).
MightyGem
Thanks guys. Looks like what I need.
And then the back wheel becomes the front wheel becomes the spare wheel becomes the back wheel.
Scooterdude
MightyGem wrote: Mon Dec 03, 2018 10:43 pm
Yes it does seem a bit like that doesn’t it?
    Users browsing this forum: No registered users and 93 guests
