GP tail light bulb blowing
- Main scooter: lambretta gp
sorry i should have read the post more carefully, i would guess at a bad earth on the back light could be to blame, i always run one from maghousing to frame then regulator, then onto back light, might be worth a try
When I've had an over voltage from the Reg. It always seems to get the rear light first. Gawd knows why!
If you have a multimeter? Check the output. Expect anything between 11v and 13v, they aren't that accurate.
