difficult neutral
Daggs
Any thoughts appreciated.
Standard Li150 gearbox. Goes through the gears static. Goes through the gears when riding, except, finding neutral when slowing down. It's really difficult, end up struggling between first and second before double-handed wrench into neutral. :cry:
garry inglis
Just slacken off on one or the other a few runs try that and a bit more if needed
holty
Main scooter: lambretta gp
do you have clutch drag ?
holty wrote: Wed Sep 19, 2018 9:45 pm do you have clutch drag ?
+1 I would check that first
Daggs
It's not cables and the clutch is fine. keep the ideas coming :)
garry inglis
Headset off and see what's happening could be outer has come out of slot
Daggs
A bit more info. It's none of the obvious things. It's been like it since I built the engine over a year ago. Initially I thought (hoped) it would ease as the scooter was used. Perhaps a sharp edge in there somewhere was snagging? But no change after more than 1200 miles.
garry inglis
Well I would take side off check the clutch and endplate off and check gears you might have 2nd gear with the boss the wrong way the tree could be chipped or worn
holty
maybe the cursor is stiff on the layshaft, did you test fit it and made sure it would slide backwards and forwards freely, before the spring and balls where installed ?
garry inglis
It definitely needs open heart surgery
    Users browsing this forum: Google [Bot] and 57 guests
