carb help please
Steveshipley
Main scooter: Sx150
MBRT195 MB CLUBMAN 30mm delorto no filter.
timing 17 degrees.
40 slide
128 main
70 choke
55pilot
Av264
X13 2.5 clip
air screw 2.5 turns
runs great on half to full throttle, but really boggy low down. struggling a bit now. any suggestions gratefully rec'd
Cheers Steve
Daggs
You need to look at your pilot jetting area.
Maybe a 50 pilot, which should allow you to reset the air mix screw to about 1.5 turns.
You don't mention what effect the choke has ................
You could fit a gauze filter which would help low speed running. But of course it may well affect mid and high.
Avantone
Check the float height if you haven’t already as quick and zero cost.
If it’s wrong, once corrected, check the needle height and main jet size as these might have been adjusted to compensate.
Tony
www.lambrettagearbox.com
Daggs
The Main jet is irrelevant to low down running.
Avantone
Daggs wrote: Sun Jun 10, 2018 9:23 pm The Main jet is irrelevant to low down running.
They overlap.
Tony
Daggs
Hi Tony.
When someone is clearly having some difficulty in accurately jetting' the carb. on his scooter, as is 'Steveshipley' I feel it's best to advise treating the 'low' 'med' 'high' areas of the carb. separately.
As your chart shows, the main jet plays no role until quarter throttle and only a tiny role between quarter and three-quarter, effectively irrelevant.
I take this approach to try and avoid confusing anyone asking 'jetting' questions. So often on forums such as this, posters offer all sorts of advice, veering into 'is the exhaust the right one, perhaps the gearing is wrong, maybe you've bought dodgy fuel and so on.
When I first began to teach myself 'jetting' I stuck to the three areas method and have had plenty of success (often over a frustratingly long time, but I got there)
Sorry for the lecture and I'm really not having a dig at you. But simplicity is the key to helping someone in 'Steveshipley's' position.
Steveshipley
Main scooter: Sx150
thanks chaps, great help as ever. 52 pilot and air screw 1.5 turns made a difference. happy now.
    Users browsing this forum: Amazon [Bot] and 91 guests
