Hmm...
I have just replaced a wonky rear brake cam and fit new newfren pads and now it's binding.
I can turn the the hub by hand but it's stiff.
Are these pads a little thicker?
I could tell that the cam was a bit thicker than the one it replaced but I thought that it was because the old one was worn.
Rear brake binding
- GTFOMWSC
- Main scooter: GP230 Super Monza CS Tuned
i had the same issue with some newfrens that i bought so binned them put some others on and it was fine,yes it appears some of the sets are a little thickerFux wrote: ↑Mon Feb 19, 2018 10:50 pm Hmm...
the man don't give a f@@k
- Main scooter: li150 S2
Sorted now.
I measured the Newfren pads and a set of Makino and they are the same thicknes.
My cam was the same thickness too.
Swapped the pads and the binding has gone.
Looking at the Newfren, the brake pads are a little longer on the shoe and the wear marks from me turning the hub are on the trailing (last cm) of the brake pad.
I think if I remove that cm, that I could use them but for now the indian Makino are staying. I hope they work ok, the Newfren look cooler with the tread pattern.. haha.
