SS250 - keep centre plug or not?
alanscottj
Just finished SS250 build - it came with a centre plug rather than the usual offset. I am considering swapping it for the offset - will there be much difference power/reliability wise of doing the swap? I'm assuming that they use the centre plug for a reason? It's a pain in the backside as I have to remove the rear shock in order to get to the plug :roll: Not accessible at all for plug chops and not practical at all for gaining access at the side of the road.
Any thoughts guys?
Many thanks!
GTFOMWSC
If you do decide to change it i'd be interested in your centre plug head cowl as i'm just building an RB225 with a centre plug head and need one.
the man don't give a f@@k
Fux
Main scooter: li150 S2
I have a standard non centerd head on my SS250 but I havn`t run it yet.
Can`t see why it would be a problem. I actually don`t think I could use a centerd plug with my exhaust because I had to grind down my head cowl fixing bolt to fit the pipe already.
alanscottj
Fux wrote: โ†‘Tue Feb 20, 2018 8:46 am I have a standard non centerd head on my SS250 but I havn`t run it yet.
Spoke to Dean the other day and he recommends keeping the centre plug - it's easily accessible if I drop the shock which isn't a major job ;)
Fux
He also doesn`t reccomend TMX 35 carbs.
Can you remember your jetting?
alanscottj
Fux wrote: โ†‘Wed Feb 21, 2018 8:46 am He also doesn`t reccomend TMX 35 carbs.
I'm using 34mm VHSB not the TMX
Fux
Ahh.. ok sir.
    Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 82 guests
