Dellorto carb reducer fitting
Posted: Wed Nov 08, 2017 5:24 pm
by essexgp
Can someone tell me the easiest way to fit a new plastic carb reducer to a Dellorto 2/22 carb please
Ive tried everything I can think of and cant get it to go in
Re: Dellorto carb reducer fitting
Posted: Wed Nov 08, 2017 6:20 pm
by HxPaul
It should just push in,with a little persuation,when you have the old one out.What I did the last time I fit one,I put the reduction sleeve on the manifold and knocked the carb on with a mallet.
Posted: Wed Nov 08, 2017 7:02 pm
by essexgp
Thanks, ill give that a try as I'm running out of ideas
It definatly wont just push in
Posted: Wed Nov 08, 2017 7:06 pm
by Adam_Winstone
I tried some from one source and... not a chance of fitting it!!!!
I ended up then buying one from Scootopia, as made for their 22mm Dellorto copy and ... BINGO! Correct size and fit.
Posted: Thu Nov 09, 2017 9:00 am
by Scooterdude
You could try heating it in boiling water, that'll make it go all floppy and should be easy to fit..
Posted: Thu Nov 09, 2017 1:09 pm
by Adam_Winstone
If it is anything like the first one I bought, no way you'll get it fitted to a genuine Dellorto. Without doubt, the insert would have need to be reduced in size before it would fit.
Adam
Posted: Fri Nov 10, 2017 6:35 pm
by essexgp
Ive got a scootopia one now, going to try inserting it using a vice and some wood to protect the carb
Posted: Sun Nov 12, 2017 3:10 pm
by essexgp
Went in a treat using a vice, have fitted the Scootopia carb today, its replaced a Jetex and I have to say so far its transformed the running of my GP
Posted: Tue Nov 14, 2017 7:58 pm
by Adam_Winstone
Well done for getting it sorted.
