Now my series 3 65 eibar has a Carello rear light unit fitted, it's knackered and I want to run the BGM led rear light so is it possible to swap it over for the CEV light unit??
Cheers in advance
Rear light units
- Main scooter: Scomadi/Li150
- garry inglis
- Main scooter: ts1 230 and rb200
yes you can any s3 fits
Cheers Garrygarry inglis wrote:yes you can any s3 fits
- Main scooter: Gori200, rt195, ld150,rb20
just buy a LED lamp and call it done. Far easier ( more reliable and cheaper) to change the bulb than to change the whole tail light housing.Not normal dan wrote: ↑Mon Sep 04, 2017 4:16 pm Now my series 3 65 eibar has a Carello rear light unit fitted, it's knackered and I want to run the BGM led rear light so is it possible to swap it over for the CEV light unit??
Cheers in advance
Google search "LED 1157". They are a DIRECT replacement for your tail lamp.
- Main scooter: li150
Will they led 1157 work on ac ?
- Main scooter: Lambretta
I managed to fit the bgm (type) led into mine ok. Bit of fettling is all
Yes (technically they are off 1/2 the time but at 1500rpm and faster it's too fast to notice). I run them in all of my bikes (BGM AC stators), have for years with no problems. Any auto parts shop should sell them. If you can't find them locally try Amazon.
The LED board type tail light is an expensive solution to a cheap problem.
Thank you Grumpy
I shall get one
Robbie
I shall get one
Robbie
