can anyone with an original ignition lock and key for an early 63/64 LiS 150 Special tell me what the key manufacturer is please for the toolbox and steering lock.
I have a feeling I read somewhere it was a Fisor but it might have been a Cama. I presume that the keys have a different spec
key type for 64 LiS150
- Main scooter: lambretta 64 li 150 Special
damn.............. something causing the post submit process to lock up with a blank page tonight. ?
There was nothing to suggest that the posts had posted ...just a blank page .
sorry
sorry
- Main scooter: Lambretta LI 150 Special
Hi Johnny.
The ignition key in my 65 Special is unfortunately, not an original, and I have no steering lock key at the moment! However, there is information in Stickys book, page 257, which gives original manufacturers for model/part number, with key numbers 'from, to'.
Don't know if you have the book, but if not, please feel free to PM me with your key numbers and I will PM you the info back.
From what I can see, it will be either Cama, Fisam, Edal, Safe, Sele, Grabor, Becme, or Elesa. Quite a selection!
Martin
Martin
thank you Martin thats very helpful. Funnily enough I have scrawled CAMA next to the lock numbers on my parts search list but couldn't remember where I had found that info from. I certainly hadn't thought of looking in my Sticky manual.Martin20 wrote:Just been checking mine Johnny, and steering lock and toolbox are both Cama, according to numbers on locks! Hope this helps.
Martin.
cheers buddy
Ahhhh ha! .... Sticky has the answer . Its a Elisa key pattern .
Slimstyle 6x pole AC number range 361-370 is an Elisa pattern key . thanks for the tip to check Stickys manual Martin.
