Readspeed 5 plate
thackers
Is it recommended to soak the clutch plates as you do with a standard clutch? And is the oil used on these plates the same that's used on standard clutch systems? Thank you.
Padge
Main scooter: 1969 Lambretta gp
yes and yes
fairspares
Use SAE 90 , not ST 90 oil.
garry inglis
dont forget your 1to 1.5mm clearence on separation after you fit the circlip use the commpressor as a clutch arm and press the clutch and check for clearence
Burnside
Main scooter: Lambretta TV200
Readspeed recommend Putoline SAE 90 (comes in 500ml bottle with a pic of a Lambretta on it) with their 5 plate clutches
thackers
Thank you for the advice given, top stuff
10 inch Terror
Xbox live gamer tag: No.
Great clutch.
    Users browsing this forum: Google [Bot] and 83 guests
