Thank you very much for your help fellas.
Al
Hydraulic route through series 2 headset??
- monkey boy
nellyboyo wrote:I`ve done it as Corrado says, back through the clamp bolt hole.
Had to use a shorter Allen bolt and I made a short cone-shaped sleeve to spread the load nicely on to that shoulder on the clamp .
I`m away at work so I cant take any pics sorry .
this is what i intended to do but it is very tight, do you have a picture like this through the bolt hole?
Hope it's not too late for you, but try this link to a post of mine from a couple of years back on the very same subject ... some good advice from others who've done it
viewtopic.php?f=7&t=32319&p=239303#p239303
(truth be told, I've still not converted mine, my drum set up is pretty good. I'll prob get around to it one day)
