Page 1 of 2
Rayspeed 6 plate clutch
Posted: Thu Mar 09, 2017 2:04 pm
by garry inglis
Re: Rayspeed 6 plate clutch
Posted: Thu Mar 09, 2017 2:08 pm
by drunkmunkey6969
Get the road clutch......fit the race plates/springs
Posted: Thu Mar 09, 2017 2:11 pm
by garry inglis
Hi Dan I would think he has a few spairs that would be the way to go but I'm sure the rad will handle my power
Posted: Thu Mar 09, 2017 2:12 pm
by garry inglis
That is road not rad
Posted: Thu Mar 09, 2017 6:09 pm
by garry inglis
Posted: Thu Mar 09, 2017 6:10 pm
by garry inglis
Trying it out fits and works fine
Posted: Thu Mar 09, 2017 7:37 pm
by alanscottj
garry inglis wrote:Trying it out fits and works fine
Got one on my TS1 225 - great bit of kit
Posted: Thu Mar 09, 2017 7:39 pm
by garry inglis
Hi Alan this is my ts230 tried a reedspeed 5 plate but over 65 just slipped so this will sort it out
Posted: Fri Mar 10, 2017 12:14 pm
by dapper
Fitted one to my scoot about a year ago. Had a weird issue where it wouldn't disengage. After some serious head scratching I discovered the thread on the top of the Xmas tree was too long and the centre button of the clutch was right up against it. Took it apart and compared to a second xmas tree and found the first one was about 3/8" longer. Swapped over and all worked fine.
Just one to look out for
Posted: Fri Mar 10, 2017 3:22 pm
by kejj
Had the same x-mass tree issue. Both on my sil gp200 gearbox and my innocents pacemaker gearbox so I had to shim the sprocket 1.8mm instead of 1,2 that I originally had measured it to.
