I was removing the bearing collar by dremeling a notch in the collar and using a chisel to tap it off when I slipped and scuffed the taper,
as you can see where I've circled the scuff - its quite near the flywheel side seal, its not a deep mark but you can pick it up if you run your fingers over it, is it knackered and would damage the seal or could I smooth it down and use it? thanks Paul
damaged crankshaft oil seal face?
- scooterslag
The mack daddy on the left!
- Main scooter: honda
We used to use repair sleeves with success.
https://simplybearings.co.uk/shop/Engin ... index.html
The dark line running round the area shows where the seal runs. Smooth any roughness (to prevent inner seal damage on assembly) and carry on.
- Main scooter: Lambretta li150 special
agree.Daggs wrote:The dark line running round the area shows where the seal runs. Smooth any roughness (to prevent inner seal damage on assembly) and carry on.
- scooterslag
great, thanks for the replies, Paul
