I recently bought a s3 project that ended up having a s2 engine in it. I decided to buy an early s3 casing and transfer the internals from the s2, using this as a chance to build my first engine (after 12 years of owning 2 Vespas and 3 Lambrettas!)
All is going well and it's been a sharp learning curve with many jobs being done twice.
I have noticed that there is two types of kickstart spring (one for s2 and one for s3). What is the difference and why won't a s2 spring fit an early s3 side-casing?
Lambretta kickstart spring
- onefortheroad
- Main scooter: Li125 series 2
i think the difference is the diameter of the wire used, series 3 being thicker, so the location holes in the side case and kick start shaft are bigger to match.
win or lose have a booze
- onefortheroad
Cheers.
Is there any differences in the kickstart shafts?
I've put the s2 spring in with the s2 shaft and it seems to fit?
- onefortheroad
Cheers Paul
