Page 5 of 9
Re: oiltech casing alterations
Posted: Wed Jan 25, 2017 5:40 pm
by Scooterdude
garry inglis wrote:I've lost faith in the casing and on every run out you'll be wondering if it's going to go bang
well I Dident want to say that but yes.
Regarding oiltecs statement on this thread, was any of that explained to you before you had the work done?
Posted: Wed Jan 25, 2017 10:30 pm
by 225worb
JB weld doesnt have the same expansion/contraction properties as ally especially when your using that amount ?? ive used small amounts of it before to correct damage cases and over time it starts to lift around the edges thus allowing air/oil/fuel leaks ,,,,Seize !!!!
With the amount of expense youve put into it gutted however it maybe try go again !!!
id be interested to see which way you go as im the process of going the same way machining wise !!!!
Good luck matey
Posted: Wed Jan 25, 2017 11:01 pm
by joespeed
WHY GARY DID YOU HAVE THIS DONE!
there is only one reason why this is good idea!! the answer is to keep the innocenti number on the case and convert the small block into a large!! the better option is a new indian case.
Posted: Thu Jan 26, 2017 7:16 am
by garry inglis
It's an Indian gp 150 from 85 or was and why not I hadn't seen anything on the forum about porosity and s**t welding I bet it's got everyone thinking now anyway I am going to strip it down and get a 200 casing as the only work I can trust is my own
Posted: Thu Jan 26, 2017 8:06 am
by mick1
Can't help feeling Oiltech is getting too much "unfair" bad press out of this. His waiting list for getting a casing altered is something like 12 weeks, so that gives an idea of the amount of casings he does. This is the only negative issue that has come to light, although I'm sure there are more, it is certainly a small percentage of the work he does.
I considered a modification on my new Avanti kit, but after adding the costs of all the parts I was fitting (£2500?) I decided against it and bought a new casing. I realise the quality of the metal/alloy used in the casing can be unknown and the quality of the modification will be dependant on the quality of the casing.
Never-the-less I am having a casing modified and will build it with mainly used parts, upgrading when I am confident in the engine. The upgrade would be dependant on not only the casing, but other factors as well.
Good luck to Oiltech and remember the hundreds/thousands of successful modifications.
Posted: Thu Jan 26, 2017 9:10 am
by garry inglis
I agree with you Mick but I've just spent that £2500 and should have been fitting it in the scooter but now I am stripping everything down every nut bolt bearing seals gearbox clutch layshaft studs top end crank the work I put in to match the casing to barrel all that for £200 alteration but I don't hold grudges and iam certain my case is the only one I'll get a 200 case and carry on
Posted: Thu Jan 26, 2017 9:19 am
by garry inglis
already got a 200 casing from lambretta restore pick it up Saturday so I'll get it built next week alls good
Posted: Thu Jan 26, 2017 8:24 pm
by Scooterdude
garry inglis wrote:already got a 200 casing from lambretta restore pick it up Saturday so I'll get it built next week alls good
Bloody hell! You don't mess about do you!
Posted: Thu Jan 26, 2017 8:54 pm
by joespeed
mess about ! took well over two months to weld this case and throw it at the internet only to come to the conclusion he has made the wrong move and and a costly mistake! think before you move!
Posted: Thu Jan 26, 2017 9:14 pm
by Scooterdude
Yes hindsight's a wonderful thing, I think most of us will have done a lot of scooter stuff differently, I know I would have!
