alter gp case
- garry inglis
- Main scooter: ts1 230 and rb200
is it possible to dremmel off the lug inside the case were the brass clutch bush goes and then use the case for an li150 caseing and clutch
- garry inglis
by the way this server is not working right it just said unsucesfull post then you do it again and two go up
- drunkmunkey6969
- Moderator
- Main scooter: '69 Lambretta GP
Yes, looking into it. Cheersgarry inglis wrote:by the way this server is not working right it just said unsucesfull post then you do it again and two go up
- HxPaul
- Main scooter: lambretta Li 150
I'm sure you dont have to cut the lug off,just remove the brass bush.garry inglis wrote:is it possible to dremmel off the lug inside the case were the brass clutch bush goes and then use the case for an li150 caseing and clutch
"I'm sure you dont have to cut the lug off,just remove the brass bush."
+1
+1
- garry inglis
ive just took my li casing off and looking at were the li clutch small lever sits to the left it would catch on casting but i will just have to wait till the gp casing turns up and i will see whats to do
- sean brady scooters
- Dealer
another consideration is the kickstart ramp /end plate !
