12v bench power supply
diesel
Can any of the electrical guru's recommend a suitable power source for testing the electrics on the scooter instead of starting it up and gassing myself in the shed?
I d use either a small alarm type battery, a car battery or a car battery charger if mains power is available. Just make sure you connect an in line fuse to your test lead, 5 amp should do it 8-)
Padge
Main scooter: 1969 Lambretta gp
as above, small 12v alarm battery or car battery, 5-10 amp inline "blade" fuse, connect earth to scooter frame and positive to 12v supply on loom (disconnect from regulator first) only thing that wont work is a 12 AC horn, but you will get a "click" when you press the button when it's wired up right
Morgan
Main scooter: T5 Vespa Mk1
I've used one of the ac 230v-12v lighting transformers (under £4 from Toolstation, probably cheaper if you get it off the internet). Gives you ac so will also test if your rectifier is working (if you're using dc).
diesel
Thanks for the speedy replies Lads
diesel
http://www.argos.ie/static/Product/part ... 418754.htm
Could I connect one of these to the scoot (negative to frame and positive to loom)? or am I being stupid?
diesel wrote:http://www.argos.ie/static/Product/part ... 418754.htm
It MIGHT work diesel but automatic chargers often need a load in order for them to output any voltage. Simple charger will work but might not have enough capacity to power a headlamp. Personally I'd go for a 12v 7 Amp ph alarm battery although you will still need the means to charge it from time to time
diesel
Alarm battery it is, cheers
EddieStone
Fit an inline fuse in the positive lead of the battery.
diesel
EddieStone wrote:Fit an inline fuse in the positive lead of the battery.
Already done. Cheers
    Users browsing this forum: No registered users and 21 guests
