Lambretta series 2 headset rebuild
watto66
Hello all
I'm getting fed up with the vibration coming from my old worries 2 handlebars / headset at certain speeds it's quite painful after awhile on long journeys does anybody make a upgrade rebuild kit , I know MBD does a late series 3 one . Any ideas
Thanks
HxPaul
It may not be the headset,if the vibration is bad you should look at the engine mounts/silent blocks.
EddieStone
Also the dreaded twisted crank
Burnside
Main scooter: Lambretta TV200
My Eibar S2 does suffer from headset vibrations at around 3-4k revs but clears once it gets into the power band, but I put that down to the Scootopia engine mounts. Simple solution is to keep it in the power band :twisted:
watto66
Thanks guys
I'm rebuilding the engine over the winter so I'll change the mounts etc at 60mph it's fine at 50mph horrible
    Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 77 guests
