Lambretta 'breathing problem'
Scootermonkey
Any ideas on this one guys? Lambretta, 175 top end, 42mm clubman, 22mm carb. Starts first go from cold but quickly starts choking itself. Take the air hose off, runs sweet as a nut! Put the rubber back on and it dies. Clear airway through hose and air filter box/scoop. Even removed the filter element. Tried three Jetex carbs, one brand new and was running perfect on another scooter. Tried a brand new Scootopia carb, tried and tested on yet another scooter. Think I've tried every jet/slide combination, still no joy. Starting to annoy me now. Never had this problem before. Any help appreciated
How hard can it be!
Lambretta, the finest scooter............IN THE WORLD!
Knowledge
Is the restrict or still in the air scoop under the seat? If in doubt, remove the air scoop but keep the air box, just in case it is the air scoop (though this is usually an issue when running at mid to high revs)
Martin
Muppet
try changing the air box for a GP one
C’est la vie
Scootermonkey
Changed the airbox and scoop for a S3 one, not even using a filter element. Airways completely clear
How hard can it be!
Chris in Margate
Suddenly happened, slowly got worse, or always been like it ?
bristolmod
air hose weak and collapses under load? Try another air hose.
Scootering since 1968.
EddieStone
Is the choke cable/mech working properly. I'm wondering if the choke is still open a little bit, if the cable is tight or something?
Scootermonkey
Engine just had a full rebuild. So first time running. Seems to want to cut out as soon as the rubber hose goes near the carb. But will start easy from cold. Runs 30 seconds and bogs down and wwants to die
How hard can it be!
LeightonRB20
Main scooter: Alwyn Pushpak RB20
As Bristolmod says; air hose collapsing. A problem with some Asian imported parts. Try another one that you know works.
Scootermonkey
The rubber is brand new, but I'll check it anyway. Cheers
How hard can it be!
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 19 guests
