Currently have a 30mm Dellorto PHBH on my TS1-225, I have the opportunity now to try a Mikini TMX 35. What's people's thoughts on the TMX? Am I likely to see much difference?
Many thanks
Ts1 - 225 Delly 30mm verses TMX 35
- Main scooter: Lambretta GP SS250 Casa
Lambretta Series 2 Rat - RB260, SuperTourer, Cyclone 5 gearbox ๐๐
Did you ever get the Dell'orto set up correctly? You were going to get it on the dyno last month?
Please don't assume that just changing carb will make it easier to set up. The same principles apply to setting up a Mikuni as do a Dell'orto. I think the TMX has a fixed atomiser , possibly.
Different engine mate, last month I was playing with the Mugello on a Series 2, this ones on my GP it's running great btwstorkfoot wrote:Did you ever get the Dell'orto set up correctly? You were going to get it on the dyno last month?
I recently asked this same question to darrell taylor as i was taking my scoot up for some runs/work on his dyno. He told me the difference in performance would not be worth the cost of the carb.
- Main scooter: Li Avanti 225
Swopped to a TMX 35 on my Avanti and noticed a big difference. More power and swifter response. Slightly less mpg and doesn't kick off quite as easy but may need tinkering with. As it runs so well when going i'm inclined to leave it as is.
- Main scooter: GP RS200 Iron barrel
What did you have before and was that setup perfectly?mick1 wrote:Swopped to a TMX 35 on my Avanti and noticed a big difference. More power and swifter response. Slightly less mpg and doesn't kick off quite as easy but may need tinkering with. As it runs so well when going i'm inclined to leave it as is.
can't comment against a 30m
Have a few bikes with mikuni's, in fact swapped over from Dellorto 34's
I find easier to set up, better fuel economy and less spit back
I suppose its going to be like most things in Scootering, some think it'll be worth it others may not. Just interested to hear if there may be any improvements as I already have the carb I'm just building motivation to try it
- paulnobodyimportant
- Main scooter: varies
I've a 30PHBH with power jet on a Monza 225 and a TMX35 on a TS1. Both dynod and approximately the same 20BHP. In reality, a slight discernible difference for me. The TMX does show far better response to the throttle and revs far quicker, only because its a flat side that controls the air flow far better than a round slide when accelerating. But all of this could also be down to other factors within my scooter engine setups.
But, if I was to choose between both it would be the TMX, far easier to set up as it has a fixed atomizer, so you are only fiddling with the needle. However, this fixed atomizer is its achilles heel, in that it wears with time and cannot be replaced. You get over this by changing to leaner needles, until you run out of options. Its OK for me as I don't do yearly mile munching trips, which would clearly wear out the atomizer faster than I have, especially if you run open mouthed.
