coil help please !
scootcoot
Hey .. my mates lammy has a lml type ignition coil the type with one spade connector which a green wire from the loom connects to ? the coil itself is blue ! how would you change this to the px ducati type coil ? as there seems to be more connections needed for to do this ? :?
am a doogal r u a doogal too....!
scootcoot wrote:Hey .. my mates lammy has a lml type ignition coil the type with one spade connector which a green wire from the loom connects to ? the coil itself is blue ! how would you change this to the px ducati type coil ? as there seems to be more connections needed for to do this ? :?
Has his scoot got points ignition?
scootcoot
no..electronic ignition
Should be a straight swap for the PX type, those are usually marked green , green, white, red (verde, verde, bianco, rosso if Italian )
Those should match a green white and red from your stator and the green from the loom.
Grumpy225
Sounds like a 2 piece CDI set up.
Trace the wires from the stator and see where they go. I'm betting a couple of them go to a little grey box and one goes to the coil.
johnd
Main scooter: 1970 Dl125
If its an LML CDI and separate coil i would leave it alone as long as its working ok, they are a pretty reliable set up.
Rule Number one!! If it ain't broke don't fix it.
    Users browsing this forum: Google [Bot] and 37 guests
