NK Exhaust Sleeve
Posted: Tue Mar 11, 2014 9:35 pm
by Spud
I'm looking for one of the sleeves that fit over the join of the end can to the exhaust?
Its for an NK road, anyone know who sells em?
cheers
Spud
Re: NK Exhaust Sleeve
Posted: Wed Mar 12, 2014 1:16 am
by corrado
PM sent.
Posted: Wed Mar 12, 2014 1:57 pm
by nellyboyo
Sleeves ???
I`ve got one and it does blow a bit here , is that the concern ?
Posted: Wed Mar 12, 2014 6:36 pm
by 10 inch Terror
If you mean the rubber sleeve that's supposed to stop oil leaking from the joint, don't bother. They don't fit very well and still leak.
Posted: Wed Mar 12, 2014 8:28 pm
by corrado
Mine fits and works, go figure.
Trick is getting one that's the right size at each end and is tight to get on.
Posted: Wed Mar 12, 2014 10:22 pm
by carlos fandango
Yes they work great
ive got readspeed ones on a jl and on an nk , niether leak. Mine are cable tied at each end .
Posted: Wed Mar 12, 2014 10:36 pm
by shocky
I used some copper wire each end one I fitted for someone
Posted: Thu Mar 13, 2014 6:46 am
by 10 inch Terror
I've had two 'perfect fit' ones before. For a Jl and NK pipes, both were complete rubbish. I must be the most unluckiest consumer on planet earth!
Posted: Thu Mar 13, 2014 8:09 pm
by MAB
Electric Heat sleeve IMOP is a far better looking and tighter seal.
