Just leaving work. Bang and a bit misfire then dead. No compression at kicksart.
Ooops holed piston ????
Should of took the running in more serious
oops gp 205 gone pop
- Boothy_the_makem
- Playstation gamer tag: Phantomkiller_uk
- Main scooter: modded t5 classic wi a parker
Canny lass, Geordie girl, he gave her pints and fags and grub and shorts. Canny lass, Geordie girl, she gave him earache and penal warts,Penal warts.
- drunkmunkey6969
- Moderator
- Main scooter: '69 Lambretta GP
It's not the 'running In' (or lack of) which causes holed pistons......mostly it's lean jetting.Boothy_the_makem wrote: Should of took the running in more serious
- Boothy_the_makem
I posted a reply earlier but it hasnt registered ( shitte phone)
Anyway thanks for that monkey. I thought maybe my over exuberance with the throttle early on and maybe poor bedding in had led to friction and overheating.
I think the jetting is high if anything . I've kept it as is from when I bought it and resisted the temptation to lean the jetting
Its a ball ache but im looking on the positive. It gives me chance to strip some of the scoot. Check it over. Get someone experienced to check it lol .
Sort some things I werent happy with but most important find out why it did what it did.
Ive started stripping it today
- Boothy_the_makem
Only two months since I took the exhaust etc off lol
So yesterday I strpped barrel and head off.
Piston is mint. Rings are fine. No damage to bore.
Conrod and crank fine...
So Im sitting on the shitter typing this today and thought I would just check the flywheel before I post.
Yep its sheared the rivets
- Boothy_the_makem
Well obviously there was compression I just assumed there wasn't as there was significantly less resistance kicking it over lolmick1 wrote:How does the flywheel rivets going explain the lack of compression ? am i missing something
Anyways as yer can imagine am over the moon the piston an crank etc are ok hahaha
- corrado
- Dealer
- Main scooter: Lambretta GP
- Boothy_the_makem
corrado wrote:That's taking multi tasking to a whole new level.Boothy_the_makem wrote:
Thats nowt mate.
One time I was on the crapper. Typing on me phone AND smokin a tab
The problem came when I went ter put the tab down the crapper and burnt me cock
No ash-tray provided.......might be worth a claimBoothy_the_makem wrote:corrado wrote:That's taking multi tasking to a whole new level.Boothy_the_makem wrote:
Thats nowt mate.
- Information
Who is online
Users browsing this forum: Ahrefs [Bot], Google [Bot], Semrush [Bot] and 46 guests
