PM crank
Posted: Fri Jun 07, 2013 9:23 pm
by sydduckett
Anyone using one of these from PM? Looking for a balanced one for an RB. Would be good to get some feedback before weighing any money out.
http://www.pmtuning.co.uk/pm-tuning-pro ... etta-gp200
ta
Re: PM crank
Posted: Fri Jun 07, 2013 10:13 pm
by Angry Bloke
I'm using one with an Avanti kit but running in so can't really give an opinion . It certainly looks and feels well made though
I took it to CS engineering to check for true before fitting and Chris was impressed ,so that's a good start
Re: PM crank
Posted: Fri Jun 07, 2013 10:16 pm
by Angry Bloke
Angry Bloke wrote:I'm using one with an Avanti kit but running in so can't really give an opinion . It certainly looks and feels well made though
I'm sure I paid less than £300 a few months ago
Re: PM crank
Posted: Fri Jun 07, 2013 10:21 pm
by sydduckett
Angry Bloke wrote:Angry Bloke wrote:I'm using one with an Avanti kit but running in so can't really give an opinion . It certainly looks and feels well made though
Any good peachy?
Re: PM crank
Posted: Fri Jun 07, 2013 11:56 pm
by Angry Bloke
sydduckett wrote:
Any good peachy?
Hi Sef, Its been Ok so far but I haven't given it any stress TBH , solid build ,as I said CS Eng was impressed
Re: PM crank
Posted: Sat Jun 08, 2013 7:35 am
by drunkmunkey6969
Great little cranks those. I use the 62/116 in RB250 builds.
Re: PM crank
Posted: Sat Jun 08, 2013 7:32 pm
by wezly
Worth checking the clearance on the big end shims, the one I had was tight and needed opening up.
Re: PM crank
Posted: Sun Jun 09, 2013 8:09 pm
by sydduckett
Do they come with a selection of shims?
ta
Re: PM crank
Posted: Sun Jun 09, 2013 8:48 pm
by Spanish Fly
sydduckett wrote:Do they come with a selection of shims?
ta
The shims go either side of the con-rod. They are there to stop the con-rod rubbing on the crank flywheels. If the flywheels have been pressed in too far onto the crank pin during assembly the clearance between the rod, shims and flywheels will be too tight which could cause a seizure when engine warms up. The clearance cannot be increased by a regular home mechanic without specialised tooling.
SF
