JL3 rubber sleeve
newmanlammy
Who sell the new rubber sleeves that were brought out recently to stop oil spitting out of the rear slip joint on JL3 pipes, I can find them on ebay but they come to about £14 with postage. Sure i've seen them advertised somewhere for about £7.
jonny wadd
Xbox live gamer tag: swingin meeet
Main scooter: lambretta gp200 electronic
Readspeed sell them
milf hunter
molibdimum
http://www.ekmpowershop2.com/ekmps/shop ... 5159-p.asp
Can someone explain this bit to me?
THE RUBBER HELPS TO REDUCE EXCESS 2 STROKE OIL IF THE EXHAUST RUNS SLIGHTLY RICH
handofdave
Main scooter: li ts1
just use some high temp silicone on assembly and it stops the leak no rubber needed
Craig H
You could try heat shrink?
Skar
Cut up a mountain bike inner tube.
Bren
Main scooter: Lambretta S-Type 225
I use a bit of car radiator hose. Works a treat..!
You need one that has different sizes at either end. The tube on the silencer part is smaller than the main pipe it fits into.
newmanlammy
Just ordered some high temp silicon hose reducers with the correct diemeters to try, will post pics if they fit ok
handofdave wrote:just use some high temp silicone on assembly and it stops the leak no rubber needed
Ditto, works for me too 8-)
    Users browsing this forum: No registered users and 80 guests
