back wheel wobble
Might be lucky and be repairable with helicoils ,then new studs and loctite and back together. Be worth using nordlock washers if not certainly best to get some new wavy washers and use loctite on the nuts.
- Main scooter: Lambretta
Agreed, time serts might be an option but you need to get a good engineer to fit them for this to work on the end plate, they need to be drilled dead straight and central, so take your end plate as well.
Go see the big boy ratty"sigh" Or was it THAT big boy"again",,,,,,,,,,,,,,,,,,bigger"sigh"ratty wrote:found the problem, end plate was loose,its pulled every stud out and chewed all the nuts up, can this be repaired properly or should i be looking for a new engine,
Brighton F.C-LOL
