Yes N3 is the same as B8dirtyhandslopez wrote:Have been instructing my customers to use Champion since day one. The electrode protrudes a little further into the combustion chamber. They are also what I see recommended in al the tech books from the 50/60/70's etc.carlos fandango wrote:Yep ! never use NGK as they seem to fail for no apparent reason only use Champions , but not as easy to get at dealers , so when i see some i always buy a couple
Same thing here with the dealers, all they want to sell is NGK's.
The problem comes when changing between NGK and Champion, ie I know an N3 is a cold Champion plug, but the number go the other way with NGK, so an 8 is is cold plug,(the no.s go bigger when colder, just one more thing to have to remember). Add that to the fact that when you go to an automotive place to buy a plug, the desk person may cross reference across the wrong lin in the book and thereby the customer might end up with the wrong plug and bam! heat sieze.
Stick with the one, the only one, Champion...
A quick tip, the numbers add up to 11 so if you use an NGK B7 the champion equivalent is N4. Therefore B9 = N2 etc
Russ
