Can anyone tell me what the correct fixing clip is for INNOCENTI SQUARE TYPE HORNCAST BADGE .FITS LATE TYPE LI3 SX (sorry about caps pasted it...
Links appreciated, it has 5 pins on the back with one being in the middle.
Ta
Sef
badge question
- soulsurfer
http://www.scooterrestorations.com/lamb ... adge-clip/
Mind you, they normally have a small nylon insert in the middle in which the middle pin on the badge goes, the other four pins just locate in the horncasting recess.
cheers for that, doesnt look as though they sell the nylon insert..... and im guessing its not going to be anywhere near tight eneough without it....soulsurfer wrote:http://www.scooterrestorations.com/lamb ... adge-clip/
Any suggestions on where to locate this bit, im going to do some searching. Not sure what to type though....
- soulsurfer
I'd check with SR, they've always come with the ones I've bought from different places, but most dealers sell the complete clip.
Nylon centre???
You'll have to check the sizes, it equals 4.7 mm X 3.175 mm, which is about right I think.
I have also bought them from Scootopia for the rear frame badge on a GP.
Rich
Rich
- soulsurfer
40 of 'em, that should last a while...!22/2 wrote:Nylon centre???
Rich
The clip should come with it anyway, mine always have, but judging by the SR pic, maybe you need to check... it may just be a mistake in the picture.
If you do check with SR can you let me know?
- Main scooter: The Biriani Bullet
You may find they are the same size as the ones SR do for the rear frame loop badge (as for SIL badge) I got some with my badge from SR
http://www.scooterrestorations.com/lamb ... ame-badge/
Item No. 5 at the rear
http://www.scooterrestorations.com/lamb ... transfers/
Iv ordered it and asked that they include it. will let you know what they say or when it turns up.soulsurfer wrote:40 of 'em, that should last a while...!22/2 wrote:Nylon centre???
Rich
Ta
For the help....
cheers dappadapper wrote:You may find they are the same size as the ones SR do for the rear frame loop badge (as for SIL badge) I got some with my badge from SR
