new 5/6 plate clutch for lambrettas
- Main scooter: SIL GP200
Very nice indeed......
- bizzly
- Main scooter: Lambretta GP
I've eventually fitted mine and cant believe how soft and easy it is. It was that easy to pull the lever in, I thought that it was going to cause drag and was surprised when it didn't.....best clutch I've ever had....no slip...no drag Best start saving up for another for my other scoot now
- Toddy
- Main scooter: Lambretta Series 1
Have you done many miles on it then ??bizzly wrote:I've eventually fitted mine and cant believe how soft and easy it is. It was that easy to pull the lever in, I thought that it was going to cause drag and was surprised when it didn't.....best clutch I've ever had....no slip...no drag Best start saving up for another for my other scoot now
- bizzly
lol....about 3....only had shorts on and thought I had best come home and get dressed proper to go out again....lmaoToddy wrote:Have you done many miles on it then ??bizzly wrote:I've eventually fitted mine and cant believe how soft and easy it is. It was that easy to pull the lever in, I thought that it was going to cause drag and was surprised when it didn't.....best clutch I've ever had....no slip...no drag Best start saving up for another for my other scoot now
- Toddy
nice onebizzly wrote:lol....about 3....only had shorts on and thought I had best come home and get dressed proper to go out again....lmaoToddy wrote:Have you done many miles on it then ??bizzly wrote:I've eventually fitted mine and cant believe how soft and easy it is. It was that easy to pull the lever in, I thought that it was going to cause drag and was surprised when it didn't.....best clutch I've ever had....no slip...no drag Best start saving up for another for my other scoot now
- Main scooter: Serveta Jet 200
I've just put my name on the list for the next batch
It took me ages to find this post, shouldn't it be in the Dealers Section ?
Great looking clutch, does it need any speacial tooling or does the standard clutch tools fit?
thanks
thanks
11111111 = 0xFF
No fancy tools just normal clutch tools
- bizzly
You might find that your standard clutch spanner doesn't fit as well, but I still held mine ok-ish with it.CANbus wrote:It took me ages to find this post, shouldn't it be in the Dealers Section ?
thanks
