Hi
Was also wondering what chain sproket to go for,at the moment its a 46/15 set up, will be using 175cc cast set up, 28mm delloroto carb, 150 gearbox I think, not sure what pipe, any suggestions would be greatful
cheers scotty
Another chain?sproket Q,s
first you need to know what gear box you have and then what pipe ,one up two up ,size of driver
Not sure about gearbox, stripped and put back togther not sure what 1 it is, indian, will be using just 1 up weigh around 85 - 90 kgs, exhaust looked at so many not sure about tha either.
Scotty
Scotty
