Stripped casing threads
jimmo
Main scooter: Lambretta GP TS1 230 JB
I have a couple of stripped casing threads where the bracket for my Taffy pipe mounts.
What size helicoils will I need and where's the best place to get em from?
Thanks ;)
Supereibar
PM cezeta he knows a good brand!!
joespeed
you could try step studs,tap the hole 7mm and just screw step stud in,
i think 8mm to 6mm are also available,
regards
joe
fred
m6 thread insert,such as helicoil. check on e bay.
used 'em for years.
The main exhaust side casing studs are 8 x1.25 mm only early series 1&2 are 6mm
jimmo wrote:I have a couple of stripped casing threads where the bracket for my Taffy pipe mounts.
Thanks ;)
Is that the tailpipe end or exhaust body end?
fred
i thought he meant muffler bracket,heliciols good for ali thread repairs.
jimmo
fred wrote:i thought he meant muffler bracket,heliciols good for ali thread repairs.
Yes Fred, its the 3 that hold on the rear bracket for the end can.
So I go for the m6 inserts then?
Should get those on ebay?
    Users browsing this forum: No registered users and 68 guests
