Semi hydraulic set up
psychedelicropcircle
The plunger on the remote master cylinder is not fully returning keeping the brake on slightly, is this Donald ducked? If so it’s the grimeca one where would I get one pronto style?
hendy
Does it return ok when the cable is disconnected?
No It doesn’t return I’ve ordered 1 from Europe
Muppet
the pin that the lever pivots on can corrode and stick which stops it from working smoothly makes it stick; take the two little circlips off remove the pin clean it up use copper slip on the pin and pivot and it might work
C’est la vie
    Users browsing this forum: Google [Bot] and 67 guests
