Gran Turismo GT200 Big block - PHBH 30 Jetting Advice Please
Bidsy
Main scooter: Lambretta S2 Eibar Li150
Sun Feb 10, 2019 3:14 pm
Hi
Just built a Gran Turismo GT200 Big block engine and after some jetting recommendation please.
My set up is 30mm PHBH, BGM V4 clubman, 18/47 SX200 gearing.
Anybody with a similar setup?
garry inglis
ebay user ID: garry52uk
Sun Feb 10, 2019 3:36 pm
145 main 55 pilot av266 an x7 second clip should get you started then check plug for fine tuning
Bidsy
Sun Feb 10, 2019 10:00 pm
Is a 145 main a little bit rich
garry inglis
Mon Feb 11, 2019 9:04 am
It's a freshly built engine and you want it rich and for the first 500 miles you won't hit full throttle to use the main properly as I said it's a starting point as you put the miles on do plug checks but from what I've seen posted over the years with jetting for this kit they end up on 140/145 That's why you start rich
Bidsy
Mon Feb 11, 2019 10:42 am
Thanks Garry, better order so more jets then. Cheers
Lambretta Sash
Main scooter: Lambretta TV 230
Sat Mar 02, 2019 10:13 am
After building a few and running Gt200 on my lammy for a few years, here's my set up with TT evo pipe and not much different with Ron moss pipe. Final ratio 4.6 using close ratio box
140 main 55 pilot 40 slide x13 av268
kejj
Sat Mar 02, 2019 9:33 pm
With a v2 bgm i never went further up than 135. Now setting up with fran race and egt I am at 134. Flat out motorway speed.
Sent from my iPad using Tapatalk
________________________
http://tv175.wordpress.com/
