Mod 1 and 2 On Scooter
GTFOMWSC
pooliepfr wrote: Wed Sep 04, 2019 8:11 am
GTFOMWSC wrote: Wed Sep 04, 2019 6:58 am as said above the only real issue with taking it on the 125 is the speed trap it will struggle to get there and would be a fail if it didn't get up to the speed.As suggested use a rider school bike have a few lessons with it to get used to it there 125's should do the speed trap or a bigger one of there's a 250? then go back to yours after you've passed.Would be a shame to go through all the effort to not get it through lack of the scooters power.
What's the speed trap?
you have to reach a certain speed in mod 1 and then brake in the box to show you have control of the bike in an emergency stop.Usually you set off,head round the bend set out and then straighten up,head for the trap then hit the brakes without hitting any of the cones or crossing the line.When you take the lessons they'll show you it but you have to reach a certain speed which you will struggle on a standard 125 a kitted one would be fine but that then is illegal(good old catch 22).
the man don't give a f@@k
Burnside
Main scooter: Lambretta TV200
IIRC you go through the speed trap twice, once for the emergency stop and once for the hazard avoidance. You need to do a minimum speed of 50kph, which isn't much but you only get a short run to get up to that speed which a standard 125 may struggle with. Fail to reach that speed and you fail the test.
GTFOMWSC
Burnside wrote: Wed Sep 04, 2019 12:06 pm IIRC you go through the speed trap twice, once for the emergency stop and once for the hazard avoidance. You need to do a minimum speed of 50kph, which isn't much but you only get a short run to get up to that speed which a standard 125 may struggle with. Fail to reach that speed and you fail the test.
ah yes forgot it was twice been a while ago that i did it
    Users browsing this forum: Ahrefs [Bot] and 48 guests
