Softer Stand Spring
Can you get softer stand springs that don’t clatter the rear runners and are easier to push off the stand?
- garry inglis
- Main scooter: ts1 230 and rb200
I think you'll find the stand drops down while riding with a softer spring that's if you could find one
- HxPaul
- Main scooter: lambretta Li 150
If its hard to push your scooter off the stand,it maybe that your stand is to long/it maybe that your stand bolts have come loose,causing the stand and the scooter to sit lower than it should.As for the stand hitting the rear runners,when I push my scooter off the stand I prevent the stand from hitting the rear runners with my foot.
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
I think that no innocenti stand had the little bit on that a rubber was put over- Its one of the things the Spanish
/Indians improved IMO.
Scootering since 1968.
