Nordlock washers
GTFOMWSC wrote:
shocky wrote: Thu Nov 23, 2017 6:23 pm I've never had any come Loose on any of my 3 scooters or any I've fittex them too on my vespas I replace the existing hub studs with 12.9 tensile dome allen capped bolts threadlocked in
I also never use the long nuts supplied (altho I do on other people's scooters if they wish)
Preferring to use knuts
Sent from my SM-G903F using Tapatalk
got there and back from Warmwell a 350 mile round trip but must admit i stopped 3 times in the first 40 miles checking but all was good so just went with it.I don't like the long nuts either was looking at those knuts but didn't know if they were good to use.Irony was i went out yesterday on one of my other scoots and that has nordlocks on but with split rims and never even thought twice about it,i'm afraid paranoia gets to you when it happens my mate Pat had his wheel come off and it took him ages before he stopped getting worried.
Martin at just lambretta recommended them and I haven't looked back Image
GTFOMWSC
shocky wrote: Thu Nov 23, 2017 7:35 pm
now they look like that's what SIP should supply why the hell don't they ffs
the man don't give a f@@k
GFlint
Main scooter: Vespa PX200
Do you still need washers with knuts both on normal split rims and Sip Tubeless?
Thanks
If you don't tinker, you won't learn anything, but you won't break anything either :)
GFlint wrote:Do you still need washers with knuts both on normal split rims and Sip Tubeless?
Thanks
I still use them
GFlint
Tks Shocky,
Lock washers on split rims and Nords on Sip or either or ?
Gary
GFlint wrote:Tks Shocky,
Gary
I use the lock washers and knuts on
Both types of rims altho my sprint has an alloy F A Italia front rim and sip rear
GFlint
We used the Nordlock washers at work, the newer X-series look good.
There are different standards of k nuts, brass, silver, white zinc and the more expensive aerospace versions, guess most use the silver or white zinc for their scoots?
GFlint wrote:We used the Nordlock washers at work, the newer X-series look good.
I do
    Users browsing this forum: Ahrefs [Bot] and 25 guests
