Page 1 of 6
Mb rear bearings
Posted: Fri May 12, 2017 1:54 pm
by garry inglis
Having to change the rear bearing after 1000 miles did a 70 mile trip yesterday and noticed a bit of movement from the rear thought it was tyre pressure but on checking to mutch play for my liking
Re: Mb rear bearings
Posted: Fri May 12, 2017 2:12 pm
by fluff34567
Is this the rear hub bearing or the gearbox bearings?
Posted: Fri May 12, 2017 2:26 pm
by garry inglis
rear hub bearing the middle part has give way i had about 5mm play top to bottom
Posted: Fri May 12, 2017 4:48 pm
by holty
thats a little bit annoying, you wouldnt expect it to fail so quickly, i presume box was shimmed correctly and filled with oil, you would expect that to be a quality bearing that would last a long time, have you contacted mb ?
Posted: Fri May 12, 2017 5:03 pm
by garry inglis
Yes shimmed correctly oil in I bought it off another dealer Christmas time it just started on this ride was doing a 30 mile stint on a1 as I say thought tyre pressure but when I got home got hold of wheel and didn't like the amount of play so stripped it thinking endplate nuts but all was ok apart from the bearing I have one in my rb with 2000 miles on that's ok anyway new parts on way
Posted: Fri May 12, 2017 9:05 pm
by joespeed
i cant remember changing a rear hub bearing in the 70's and did 100 miles a night let alone weekend trips to the coast and was nearly always two up!
Posted: Sat May 13, 2017 7:32 am
by GTFOMWSC
Same here done 100's miles back in the 80's and never needed to change one now it seems I need to change one on every scoot I ever get.Maybe it was because I was used to just sliding around and thought that was the norm back then.
Posted: Sat May 13, 2017 8:40 am
by garry inglis
I wouldn't mind the original one I tapped out is still in good condition but if you put it all back together and find it isn't you'd well pissed
Posted: Tue May 16, 2017 6:05 am
by garry inglis
all back together and no more wobble
Posted: Tue May 16, 2017 8:03 am
by garry inglis
