Jetting Dellorto PHBH 28mm
Posted: Sun Feb 05, 2017 10:04 am
Hi. I've looked through the carb set up section on here but can't find anything to match mine.
Standard SIL200 apart from Asso piston, Casatronic ignition, 42mm AF clubman. Anyone know a good starting point with the jetting for the 28mm carb. Will be fitting a Ramair filter. Any ideas welcomed.
