Cost of sending an engine?
also check the cover value if it got lost or damaged, a lot of courier companies have a £100 limit, unless you take added insurance.
win or lose have a booze
- Main scooter: Lambretta
Be careful with the likes of Hermes their T&C exclude engines or parts.
- DigDug
Don't use My Hermes unless you're not bothered about seeing your engine again.rosscla wrote:Be careful with the likes of Hermes their T&C exclude engines or parts.
Did you have to do that?
- purple_pill67
- Main scooter: Jet200
Drain the oil and pack it well
- Main scooter: honda
I sent a very heavy valve amplifier, more weight and cost than a lambretta engine.
I found a www which gave you a list of carriers which you could suss out the t&t's, costs, weights and volumes. The weight turned out to be irrelevant, volume was the thing, with a max dimention limit.
All signed for, tracked and treated well. I did take some care with packaging though - made a wooden crate and put in lots of padding.
Came back in same crate.
I'll have a look see if I can find the invoice.
As mentioned clean and drain first.
If you are sending it to a company, have a word with them see if they have any recommendations.
