12volt DC Mod charger
- Main scooter: italian gp 125
that thing looks cheaper can we make our own anyone know how to wire it
Should be able to build one much cheaper, a bridge rec (about £2) to first rectify the AC. Just Google the 7812 for smoothing cap values.
It may even be worth looking at 7805 regs to feed out straight to a usb connector.
- Main scooter: Li Avanti 225
Is there a potential problem in that at low revs it won't be generating 12v. A gps for instances, takes a bit of time to find and connect to the satellites, so at low revs it would switch off then re-start when it reaches 12v ....then switch off again at low revs.
I buggered my samsung galaxy using a gps app' on the Li and that was through a battery....some electrical appliances are a bit sensitive so be careful !!
- sideout
- Main scooter: SX150/GP Muggy/LiS3 Avanti TT3
Couldn't post a circuit diagram could you mate? It would be really interesting! You made it sound so simplefirekdp wrote:Should be able to build one much cheaper, a bridge rec (about £2) to first rectify the AC. Just Google the 7812 for smoothing cap values.
- Main scooter: Lambretta AFgp225
See these at Scarbro' this weekend... I'd priced new new stator, cdi and reg for dc conversion... Think this is worth a try first at that price.... If it does as it says.. Charges phone/ runs satnav.. I'll be happy!!...
