Fuel leak
NEW MEMBER? - You must now introduce yourself here first BEFORE you can post in any other section!
Say hello and let us know a bit about you and what scooter you own, etc...THEN you will be able to post elsewhere.
Chip Panfire
I seam to have a small fuel leak between the tank and the petrol tap. I'm I right in thinking that there is a fibre washer that most likely needs replacing or is it the tap itself ? Many thanks
Welcome aboard
johnny650
Main scooter: lambretta 64 li 150 Special
welcome panfire
Tractorman
Main scooter: Lambretta li150 special
Most of the new fuel taps are self sealing and do not have fibre washers, however if yours is original it may well be the washer.
Tractorman
Sorry about the last post, I did not see your second post and for some strange reason I could neither edit or delete the post.
Chip Panfire
Thanks for the welcomes and replies, and apologies for listing this under the wrong topic. Thanks Tractorman, I think mine is original, I suppose there's only one way to find out. Thanks again.
    Users browsing this forum: No registered users and 43 guests
