NSU Prima D
OliverCiaravella
Main scooter: NSU Prima D
Hey all,
I have a NSU Prima D scooter that I believe is in maroon.
During restoration I would like to restore with original colour is there a specific paint colour to be used? For the spray shop
storkfoot
If you are on Facebook, there is a group for NSU Prima. It may be a good place to start.
OliverCiaravella
So the fun begins.
Finally got sorted and started the strip down.
Unfortunately the engine was seized up after lots of oil and heat the piston released.
Using a gudgeon pin removal tool unfortunately cracked the piston. The cylinders not in great shape so having it rebored/cleaned up.
My question is I see Prima D pistons come up as Lambretta 150 pistons, they don’t look the same but I presume size wise they are the same.Image
