How much Gear box oil
DaleUK
Main scooter: 1962 Li 125
....in a Series 3 Li125cc
GP240
book says 700mls but 500mils is mostly preferred (half a litre).
gavi4t
Main scooter: lambretta gp450
pour in the oilio englasias until it comes out of the first allen key hole while the scooters on the flat simples, usually about a pint me auld sock :D
DaleUK
Well it looks like 700 ml as come out so I'm guessing 700 back..
Chris in Margate
700 mls completely dry build
500 mls for an oil change.
As posted fill till it runs out of level hole.
eden
put your scooter level on the stand take out the higher plug and fill till it runs out of there then put the plug back in, that's why its there!
DaleUK
Ok..I hear what your saying but any ideas why just slightly over 700 ml came out??
Over filled maybe??
Yanker
eden wrote:put your scooter level on the stand take out the higher plug and fill till it runs out of there then put the plug back in, that's why its there!
Fiyne burt witch levewl paaawt ov youw skewta yew ffix tha spiweet leval orn?
DaleUK
Any more?
You've had all the answers you need, 700 fresh engine, 500 re fill, the proper way (edens answer) and yes someone's over filled if 700 came out (700 been used on top up which is to much)
