Hi all,
Dellorto phbl 25
Over night there is fuel leaking from the 2 small air holes at the bottom of the carb/mouth/venturi
could someone point me in the right direction please,float? needle?
Thanks......Steve
Carb fuel leak
- EddieStone
- Main scooter: Lambretta Li 150
Typically the float needle. Did you turn your fuel tap off?
- Main scooter: lambretta 64 li 150 Special
presumably not the answer he was looking for eddieEddieStone wrote: ↑Tue Aug 20, 2019 11:12 amTypically the float needle. Did you turn your fuel tap off?
Wouldn't be the first time that I had forgotten to turn the tap off
